problème UnboundLocalError dans une classe [Python 3.X]
    collégien
    Juillet 2014
    Activité : collégien
    Par défaut problème UnboundLocalError dans une classe
    Voici un code pour créer des pigeons (un peu comme turtle)
    #!/usr/bin/env python3
    # -*- coding: utf-8 -*-
    from math import *
    from tkinter import *
    class pigeon:
    	"""Canvas, coordonnée y, coordonnée x, degré
    Fonctions : __init__, left, right, forward, find_point, up, down, del_pointeur, pointeur"""
    	def __init__(self, canvas, coy = 250, cox = 250, degree = 0):
    		print(pigeon.__doc__)
    		if (degree < 0):
    			degree = -degree
    		degree = degree - degree//360 * 360
    		self.can = canvas
    		self.degree = degree
    		self.cox = cox
    		self.coy = coy
    		self.pointeur()
    		self.up = down
    	def find_point(self, pxl):
    		dir = self.degree // 90
    		tri = self.degree - dir * 90
    		cibley = pxl * cos(radians(self.degree))
    		ciblex = sqrt(pxl**2 - cibley**2)
    		if (tri % 4 == 0):
    			a = [-cibley, ciblex]
    		if (tri % 4 == 1):
    			a = [ciblex, cibley]
    		if (tri % 4 == 2):
    			a = [cibley, -ciblex]
    		if (tri % 4 == 3):
    			a = [-ciblex, -cibley]
    		return a
    	def left(self, d):
    		self.degree = self.degree + d
    		if (self.degree < 0):
    			self.degree = -self.degree
    		self.degree = self.degree - self.degree//360 * 360
    	def right(self, d):
    		self.degree = self.degree - d
    	def forward(self, pxl):
    		a = self.find_point(pxl)
    		if (self.up == down):
    			self.can.create_line(self.coy, self.cox, self.coy+a[0], self.cox+a[1])
    		self.coy, self.cox = self.coy+a[0], self.cox+a[1]
    		self.pointeur()
    	def up(self):
    		self.up = up
    	def down(self):
    		self.up = down
    	def pointeur(self):
    		za = self.find_point(sqrt(10**2*2))
    		self.degree = self.degree + 135
    		zb = self.find_point(10)
    		self.degree = self.degree + 90
    		zc = self.find_point(10)
    		self.point = self.can.create_polygon(za[0], za[1], zb[0], zb[1], zc[0], zc[1])
    	def del_pointeur(self):
    		del self.point
                    fen.delete(can, self.point
    voici l'erreur
    p = pigeon(can)
      File "<pyshell#38>", line 1, in <module>
        p = pigeon(can)
      File "C:\Users\fried_000\Desktop\dosssier\python\pigeon.py", line 17, in __init__
        self.pointeur()
      File "C:\Users\fried_000\Desktop\dosssier\python\pigeon.py", line 56, in pointeur
      File "C:\Users\fried_000\Desktop\dosssier\python\pigeon.py", line 32, in find_point
        return a
    UnboundLocalError: local variable 'a' referenced before assignment
    voici une autre classe qui elle, marche
    class p():
    	def __init__(self, x = 5):
    		self.l = 5
    		b = self.t(x)
    		print(b)
    	def t(self, x):
    		if (x % 3 == 0):
    			r = [0, 3]
    		if (x % 3 == 1):
    			r = [1, 4]
    		if (x % 3 == 2):
    			r = [2, 5]
    		return r
    Je ne comprends pas ce que j'ai mal fait...
    Dans votre fonction :
    Citation Envoyé par ofortuna Voir le message
    		if (tri % 4 == 0):
    		if (tri % 4 == 1):
    		if (tri % 4 == 2):
    		if (tri % 4 == 3):
    		return a
    Si aucune des conditions n'est remplie (ce qui arrive lorsque 'tri' est un nombre à virgule flottante avec décimales non nulles), votre variable 'a' ne sera jamais initialisée et donc n'existera pas au moment d'exécuter return a.
    Résultat des courses :
        p = pigeon(can)
        self.pointeur()
        return a
    Je sais que c'est impressionnant d'éplucher un traceback quand on n'a pas l'habitude, mais c'est un mal nécessaire.
    Commencez toujours par la dernière ligne du message puis remontez le message à rebours tant que vous n'avez pas compris où se situe l'erreur.
    Ici, la dernière ligne dit :
    traduit en français cela signifie grosso modo
    ErreurVariableLocaleNonDéclarée : la variable locale 'a' a été utilisée avant d'être initialisée.
    Est-ce que c'est plus clair comme ça ?
    collégien
    Juillet 2014
    		if (tri % 4 == 0):
    		if (tri % 4 == 1):
    		if (tri % 4 == 2):
    		if (tri % 4 == 3):
    		return a
    dir = 0(self.degree) // 90 donc 0
    tri = 0 - 0*90 donc 0
    tri % 4 = 0 donc [-cibley, ciblex]
    non?
    Membre Expert Avatar de plxpy
    Ingénieur géographe
    Janvier 2009
    Activité : Ingénieur géographe
    es-tu sur que le message d'erreur correspond au code que tu as posté ?
    J'ai quelques doutes.
    J'ai viré ce qui ne rentre pas en ligne de compte dans l'initialisation et les aspects tkinter, et il n'y a aucun message d'erreur.
    		if (tri % 4 == 0):
    		if (tri % 4 == 1):
    		if (tri % 4 == 2):
    		if (tri % 4 == 3):
    		return a
    non?
    La formule m = a - b * (a // b) correspond à la formule du modulo : http://fr.wikipedia.org/wiki/Modulo_(informatique)
    Or, il se trouve que dans Python, la notation a modulo b s'écrit a % b
    Maintenant, ouvrez une console Python3 ou IDLE puis testez ceci :
    >>> 125 % 90
    >>> (125 % 90) % 4
    >>> (125 % 90) % 4 == 3
    True
    >>> 125.123456 % 90
    35.123456000000004
    >>> (125.123456 % 90) % 4
    3.1234560000000045
    >>> (125.123456 % 90) % 4 == 3
    False
    Est-ce que vous comprenez mieux pourquoi vos tests ne sont jamais vérifiés ?
    Soit dit en passant, vous pouvez nettement optimiser le code de cette fonction :
        def find_point(self, pxl, angle=None):
            if angle is None:
                angle = self.degree
            # end if
            cibley = pxl * cos(radians(angle))
            tri = int(angle % 90) % 4
            return (
                [-cibley, ciblex],
                [ciblex, cibley],
                [cibley, -ciblex],
                [-ciblex, -cibley],
            )[tri]
        # end def
  1. problème Select dans une classe
    Par sky88 dans le forum Servlets/JSP
    Dernier message: 17/10/2010, 15h03
  2. Réponses: 8
    Dernier message: 12/04/2007, 12h32
  3. Problème Access Violation dans une classe
    Par randriano dans le forum C++Builder
    Dernier message: 11/04/2007, 19h49
  4. problème d'accès dans une classe dérivée!
    Par chrono23 dans le forum C++
    Réponses: 47
    Dernier message: 10/10/2006, 12h22
  5. Problème dans une Classe
    Par Orbix dans le forum Langage
    Dernier message: 02/10/2006, 15h52
