Probleme de connection au base de données
Une application .jar exécutable est fournie à l’hébergeur, lorsque que je lance le fichier .jnlp via le web pour exécuter l’application .jar ‘ développé par swing ‘ , il apparaître une fenêtre dans laquelle , il demande d’entrer login et mots de passe , on saisie login et mots pass,
Il donne ce message d’erreur :
java.sql.SQLException: Invalid authorization specification message from server: "Access denied for user: 'taogolpm' (Using password: YES)"
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:1997)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:1906)
at com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java:954)
at com.mysql.jdbc.Connection.createNewIO(Connection.java:1782)
at com.mysql.jdbc.Connection.<init>(Connection.java:450)
atcom.mysql.jdbc.NonRegisteringDriver.connect (NonRegisteringDriver.java:411)
at java.sql.DriverManager.getConnection(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
ya qlq qui tombé sur meme erreur.
j'attends tes réponses.
merci à l'avance.
