Problème de servo-moteur avec Arduino Mega et esp8266-01
j'ai un probleme de servo moteur avec l'arduino mega et esp8266-01 la page web et fonctionner bien mais le servo ne tourne pas voici le code
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165
| #include "WiFiEsp.h"
#include <Servo.h>
Servo myServo;
// Emulate Serial1 on pins 6/7 if not present
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(18, 19); // RX, TX
#endif
char ssid[] = "DJAWEB_0D19C"; // your network SSID (name)
char pass[] = "**********"; // your network password
int status = WL_IDLE_STATUS;
int ledStatus = LOW;
int led1 = 9;
WiFiEspServer server(80);
// use a ring buffer to increase speed and reduce memory allocation
RingBuffer buf(8);
void setup()
pinMode(9, OUTPUT);
myServo.attach(12); //servo pin
myServo.write(0);
pinMode(LED_BUILTIN, OUTPUT); // initialize digital pin LED_BUILTIN as an output.
Serial.begin(115200); // initialize serial for debugging
Serial1.begin(9600); // initialize serial for ESP module
WiFi.init(&Serial1); // initialize ESP module
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
// attempt to connect to WiFi network
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network
status = WiFi.begin(ssid, pass);
Serial.println("You're connected to the network");
printWifiStatus();
// start the web server on port 80
server.begin();
void loop()
WiFiEspClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("New client"); // print a message out the serial port
buf.init(); // initialize the circular buffer
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
buf.push(c); // push it to the ring buffer
// printing the stream to the serial monitor will slow down
// the receiving of data from the ESP filling the serial buffer
//Serial.write(c);
// you got two newline characters in a row
// that's the end of the HTTP request, so send a response
if (buf.endsWith("\r\n\r\n")) {
sendHttpResponse(client);
break;
// Check to see if the client request was "GET /H" or "GET /L":
if (buf.endsWith("GET /H")) {
Serial.println("Turn led ON");
ledStatus = HIGH;
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
else if (buf.endsWith("GET /L")) {
Serial.println("Turn led OFF");
ledStatus = LOW;
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
else if (buf.endsWith("GET /m")) {
led1 = HIGH;
digitalWrite(9, HIGH); // turn the LED off by making the voltage LOW
else if (buf.endsWith("GET /g")) {
//ledStatus = LOW;
digitalWrite(9, LOW); // turn the LED off by making the voltage LOW
if (buf.endsWith("GET /OPEN_P")) {
myServo.write(90);
} //else if
if (buf.endsWith("GET /CLOSE_P")) {
myServo.write(0);
}//else if
// close the connection
client.stop();
Serial.println("Client disconnected");
void sendHttpResponse(WiFiEspClient client)
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("The LED is ");
client.print(ledStatus);
client.println("<br>");
client.println("Click <a href=\"/H\">here</a> turn the LED on<br>");
client.println("Click <a href=\"/L\">here</a> turn the LED off<br>");
client.println("Click <a href=\"/m\">here</a> turn the LED on<br>");
client.println("Click <a href=\"/g\">here</a> turn the LED off<br>");
client.println("Click <a href=\"/OPEN_P\">here</a> The door is Open<br>");
client.println("Click <a href=\"/CLOSE_P\">here</a> The door is Closed<br>");
// The HTTP response ends with another blank line:
client.println();
void printWifiStatus()
// print the SSID of the network you're attached to
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print where to go in the browser
Serial.println();
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
Serial.println();
