1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
| create table t_etapes (
nsq number(19,0) primary key,
num_trajet number(19,0) NOT NULL,
nom_ville varchar2(256 char) NOT NULL,
date_arrivee date NOT NULL,
date_depart date NOT NULL
create table t_clients (
nom_client varchar2(256 char) NOT NULL
create table t_reservations (
num_client number(19,0) ,
ville_depart varchar2(256 char) NOT NULL,
ville_arrivee varchar2(256 char) NOT NULL,
nombre_places number(19,0) constraint ck_nombre_places check(nombre_places > 0)
alter table t_reservations add constraint fk_num_client foreign key (num_client) references t_clients;
create or replace view v_trajets as
select num_trajet, nom_ville, date_arrivee, date_depart,
row_number() over(partition by num_trajet order by date_arrivee) as num_etape
from t_etapes
create or replace view v_reservations as
select r.nsq , r.num_client, r.num_trajet, r.ville_depart, t1.num_etape as num_etape_depart, r.ville_arrivee, t2.num_etape as num_etape_arrivee, t.num_etape, r.nombre_places, c.nom_client
from t_reservations r
join v_trajets t on t.num_trajet = r.num_trajet
join v_trajets t1 on t1.num_trajet = r.num_trajet and r.ville_depart = t1.nom_ville
join v_trajets t2 on t2.num_trajet = r.num_trajet and r.ville_arrivee = t2.nom_ville
join t_clients c on r.num_client = c.nsq
where t1.num_etape <= t.num_etape and t.num_etape <= t2.num_etape
insert into t_clients(nsq,nom_client) values (1,'Dupont') ;
insert into t_clients(nsq,nom_client) values (2,'Durand') ;
insert into t_clients(nsq,nom_client) values (3,'Martin') ;
insert into t_clients(nsq,nom_client) values (4,'Dumoulin') ;
insert into t_etapes(nsq, num_trajet, nom_ville, date_arrivee, date_depart) values (1, 1, 'City 1', to_date('01-01-2018 08:00', 'dd-mm-yyyy hh24:mi'), to_date('01-01-2018 08:10', 'dd-mm-yyyy hh24:mi')) ;
insert into t_etapes(nsq, num_trajet, nom_ville, date_arrivee, date_depart) values (2, 1, 'City 2', to_date('01-01-2018 09:00', 'dd-mm-yyyy hh24:mi'), to_date('01-01-2018 09:10', 'dd-mm-yyyy hh24:mi')) ;
insert into t_etapes(nsq, num_trajet, nom_ville, date_arrivee, date_depart) values (3, 1, 'City 3', to_date('01-01-2018 10:00', 'dd-mm-yyyy hh24:mi'), to_date('01-01-2018 10:10', 'dd-mm-yyyy hh24:mi')) ;
insert into t_etapes(nsq, num_trajet, nom_ville, date_arrivee, date_depart) values (4, 1, 'City 4', to_date('01-01-2018 11:00', 'dd-mm-yyyy hh24:mi'), to_date('01-01-2018 11:10', 'dd-mm-yyyy hh24:mi')) ;
insert into t_etapes(nsq, num_trajet, nom_ville, date_arrivee, date_depart) values (5, 1, 'City 5', to_date('01-01-2018 12:00', 'dd-mm-yyyy hh24:mi'), to_date('01-01-2018 12:10', 'dd-mm-yyyy hh24:mi')) ;
insert into t_etapes(nsq, num_trajet, nom_ville, date_arrivee, date_depart) values (6, 2, 'City 1', to_date('01-01-2018 08:30', 'dd-mm-yyyy hh24:mi'), to_date('01-01-2018 08:40', 'dd-mm-yyyy hh24:mi')) ;
insert into t_etapes(nsq, num_trajet, nom_ville, date_arrivee, date_depart) values (7, 2, 'City 6', to_date('01-01-2018 09:30', 'dd-mm-yyyy hh24:mi'), to_date('01-01-2018 09:40', 'dd-mm-yyyy hh24:mi')) ;
insert into t_etapes(nsq, num_trajet, nom_ville, date_arrivee, date_depart) values (8, 2, 'City 7', to_date('01-01-2018 10:30', 'dd-mm-yyyy hh24:mi'), to_date('01-01-2018 10:40', 'dd-mm-yyyy hh24:mi')) ;
insert into t_etapes(nsq, num_trajet, nom_ville, date_arrivee, date_depart) values (9, 2, 'City 8', to_date('01-01-2018 11:30', 'dd-mm-yyyy hh24:mi'), to_date('01-01-2018 11:40', 'dd-mm-yyyy hh24:mi')) ;
insert into t_etapes(nsq, num_trajet, nom_ville, date_arrivee, date_depart) values (10, 2, 'City 9', to_date('01-01-2018 12:30', 'dd-mm-yyyy hh24:mi'), to_date('01-01-2018 12:40', 'dd-mm-yyyy hh24:mi')) ;
insert into t_reservations(nsq, num_client, num_trajet, ville_depart, ville_arrivee, nombre_places) values (1, 1, 1, 'City 1', 'City 3', 2) ;
insert into t_reservations(nsq, num_client, num_trajet, ville_depart, ville_arrivee, nombre_places) values (2, 2, 1, 'City 2', 'City 3', 1) ;
insert into t_reservations(nsq, num_client, num_trajet, ville_depart, ville_arrivee, nombre_places) values (3, 3, 1, 'City 1', 'City 5', 4) ;
insert into t_reservations(nsq, num_client, num_trajet, ville_depart, ville_arrivee, nombre_places) values (4, 4, 1, 'City 3', 'City 5', 3) ;
select * from v_trajets ;
select * from v_reservations ;
create or replace view v_nreservationetapes as
select t.num_trajet, t.nom_ville, t.num_etape,
sum(r.nombre_places) as n_reservations
from v_trajets t
join v_reservations r on r.num_trajet = t.num_trajet and r.num_etape = t.num_etape
group by t.num_trajet, t.nom_ville, t.num_etape
order by t.num_trajet, t.num_etape
