1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138
| /* $Revision: 1.1.6.4 $ */
* engdemo.cpp
* A simple program to illustrate how to call MATLAB
* Engine functions from a C++ program.
* Copyright 1984-2011 The MathWorks, Inc.
* All rights reserved
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include "engine.h"
#define BUFSIZE 256
int main()
Engine *ep;
mxArray *T = NULL, *result = NULL;
char buffer[BUFSIZE+1];
double time[10] = { 0.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0 };
* Call engOpen with a NULL string. This starts a MATLAB process
* on the current host using the command "matlab".
if (!(ep = engOpen(""))) {
fprintf(stderr, "\nCan't start MATLAB engine\n");
return EXIT_FAILURE;
* PART I
* For the first half of this demonstration, we will send data
* to MATLAB, analyze the data, and plot the result.
* Create a variable for our data
T = mxCreateDoubleMatrix(1, 10, mxREAL);
memcpy((void *)mxGetPr(T), (void *)time, sizeof(time));
* Place the variable T into the MATLAB workspace
engPutVariable(ep, "T", T);
* Evaluate a function of time, distance = (1/2)g.*t.^2
* (g is the acceleration due to gravity)
engEvalString(ep, "D = .5.*(-9.8).*T.^2;");
* Plot the result
engEvalString(ep, "plot(T,D);");
engEvalString(ep, "title('Position vs. Time for a falling object');");
engEvalString(ep, "xlabel('Time (seconds)');");
engEvalString(ep, "ylabel('Position (meters)');");
* use fgetc() to make sure that we pause long enough to be
* able to see the plot
printf("Hit return to continue\n\n");
fgetc(stdin);
* We're done for Part I! Free memory, close MATLAB figure.
printf("Done for Part I.\n");
mxDestroyArray(T);
engEvalString(ep, "close;");
* PART II
* For the second half of this demonstration, we will request
* a MATLAB string, which should define a variable X. MATLAB
* will evaluate the string and create the variable. We
* will then recover the variable, and determine its type.
* Use engOutputBuffer to capture MATLAB output, so we can
* echo it back. Ensure first that the buffer is always NULL
* terminated.
buffer[BUFSIZE] = '\0';
engOutputBuffer(ep, buffer, BUFSIZE);
while (result == NULL) {
char str[BUFSIZE+1];
* Get a string input from the user
printf("Enter a MATLAB command to evaluate. This command should\n");
printf("create a variable X. This program will then determine\n");
printf("what kind of variable you created.\n");
printf("For example: X = 1:5\n");
printf(">> ");
fgets(str, BUFSIZE, stdin);
* Evaluate input with engEvalString
engEvalString(ep, str);
* Echo the output from the command.
printf("%s", buffer);
* Get result of computation
printf("\nRetrieving X...\n");
if ((result = engGetVariable(ep,"X")) == NULL)
printf("Oops! You didn't create a variable X.\n\n");
else {
printf("X is class %s\t\n", mxGetClassName(result));
* We're done! Free memory, close MATLAB engine and exit.
printf("Done!\n");
mxDestroyArray(result);
engClose(ep);
return EXIT_SUCCESS;
