1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140
| package org.k.developpez.forum;
import java.lang.annotation.Native;
public class Integer {
System.out.println(Integer.toHexString(234546346));
* The number of bits used to represent an {@code int} value in two's complement binary form.
* @since 1.5
@Native
public static final int SIZE = 32;
* All possible chars for representing a number as a String
final static char[] digits = { '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'a',
'b', 'c', 'd', 'e', 'f', 'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p',
'q', 'r', 's', 't', 'u', 'v', 'w', 'x', 'y', 'z' };
* Returns the number of zero bits preceding the highest-order ("leftmost") one-bit in the two's complement binary representation of the specified {@code int} value. Returns 32 if the specified value has no one-bits in its two's complement representation, in other words if it is equal to zero.
* <p>
* Note that this method is closely related to the logarithm base 2. For all positive {@code int} values x:
* <ul>
* <li>floor(log<sub>2</sub>(x)) = {@code 31 - numberOfLeadingZeros(x)}
* <li>ceil(log<sub>2</sub>(x)) = {@code 32 - numberOfLeadingZeros(x - 1)}
* </ul>
* @param i
* the value whose number of leading zeros is to be computed
* @return the number of zero bits preceding the highest-order ("leftmost") one-bit in the two's complement binary representation of the specified {@code int} value, or 32 if the value is equal to zero.
* @since 1.5
public static int numberOfLeadingZeros(int i) {
// HD, Figure 5-6
if (i == 0)
return 32;
int n = 1;
if (i >>> 16 == 0) {
n += 16;
i <<= 16;
if (i >>> 24 == 0) {
n += 8;
i <<= 8;
if (i >>> 28 == 0) {
n += 4;
i <<= 4;
if (i >>> 30 == 0) {
n += 2;
i <<= 2;
n -= i >>> 31;
return n;
* Returns a string representation of the integer argument as an
* unsigned integer in base 16.
* <p>The unsigned integer value is the argument plus 2<sup>32</sup>
* if the argument is negative; otherwise, it is equal to the
* argument. This value is converted to a string of ASCII digits
* in hexadecimal (base 16) with no extra leading
* {@code 0}s.
* <p>The value of the argument can be recovered from the returned
* string {@code s} by calling {@link
* Integer#parseUnsignedInt(String, int)
* Integer.parseUnsignedInt(s, 16)}.
* <p>If the unsigned magnitude is zero, it is represented by a
* single zero character {@code '0'} ({@code '\u005Cu0030'});
* otherwise, the first character of the representation of the
* unsigned magnitude will not be the zero character. The
* following characters are used as hexadecimal digits:
* <blockquote>
* {@code 0123456789abcdef}
* </blockquote>
* These are the characters {@code '\u005Cu0030'} through
* {@code '\u005Cu0039'} and {@code '\u005Cu0061'} through
* {@code '\u005Cu0066'}. If uppercase letters are
* desired, the {@link java.lang.String#toUpperCase()} method may
* be called on the result:
* <blockquote>
* {@code Integer.toHexString(n).toUpperCase()}
* </blockquote>
* @param i an integer to be converted to a string.
* @return the string representation of the unsigned integer value
* represented by the argument in hexadecimal (base 16).
* @see #parseUnsignedInt(String, int)
* @see #toUnsignedString(int, int)
* @since JDK1.0.2
public static String toHexString(int i) {
return toUnsignedString0(i, 4);
* Convert the integer to an unsigned number.
private static String toUnsignedString0(int val, int shift) {
// assert shift > 0 && shift <=5 : "Illegal shift value";
int mag = Integer.SIZE - Integer.numberOfLeadingZeros(val);
int chars = Math.max(((mag + (shift - 1)) / shift), 1);
char[] buf = new char[chars];
formatUnsignedInt(val, shift, buf, 0, chars);
// Use special constructor which takes over "buf".
return new String(buf);
static int formatUnsignedInt(int val, int shift, char[] buf, int offset, int len) {
int charPos = len;
int radix = 1 << shift;
int mask = radix - 1;
do {
buf[offset + --charPos] = Integer.digits[val & mask];
val >>>= shift;
} while (val != 0 && charPos > 0);
return charPos;
