1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
| import java.io.File;
import java.io.IOException;
import javax.sound.sampled.AudioFormat;
import javax.sound.sampled.AudioInputStream;
import javax.sound.sampled.AudioSystem;
import javax.sound.sampled.DataLine;
import javax.sound.sampled.FloatControl;
import javax.sound.sampled.LineUnavailableException;
import javax.sound.sampled.SourceDataLine;
import javax.sound.sampled.FloatControl.Type;
public class MakeSound {
private final int BUFFER_SIZE = 128000;
private File soundFile;
private AudioInputStream audioStream;
private AudioFormat audioFormat;
private SourceDataLine sourceLine;
public static void main(String args[])
MakeSound ms = new MakeSound();
ms.playSound("");
* @param filename the name of the file that is going to be played
public void playSound(String filename){
String strFilename = "M1F1-int16-AFsp.wav";
try {
soundFile = new File(strFilename);
} catch (Exception e) {
e.printStackTrace();
System.exit(1);
try {
audioStream = AudioSystem.getAudioInputStream(soundFile);
} catch (Exception e){
System.exit(1);
audioFormat = audioStream.getFormat();
DataLine.Info info = new DataLine.Info(SourceDataLine.class, audioFormat);
try {
sourceLine = (SourceDataLine) AudioSystem.getLine(info);
sourceLine.open(audioFormat);
} catch (LineUnavailableException e) {
System.exit(1);
System.exit(1);
FloatControl pan = (FloatControl) sourceLine.getControl(FloatControl.Type.PAN);
pan.setValue(-1.f);
sourceLine.start();
boolean isPan = sourceLine.isControlSupported(Type.PAN);
System.err.println("Pan : "+isPan);
int nBytesRead = 0;
byte[] abData = new byte[BUFFER_SIZE];
while (nBytesRead != -1) {
try {
nBytesRead = audioStream.read(abData, 0, abData.length);
} catch (IOException e) {
if (nBytesRead >= 0) {
@SuppressWarnings("unused")
int nBytesWritten = sourceLine.write(abData, 0, nBytesRead);
sourceLine.drain();
sourceLine.close();
