File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\migrations\recorder.py", line
69, in ensure_schema
raise MigrationSchemaMissing("Unable to create the django_migrations table (%s)" % exc)
django.db.migrations.exceptions.MigrationSchemaMissing: Unable to create the django_migrations table (ORA-02000: missing ALWAYS keyword)
(venv) C:\Users\ODOO\Documents\Djano\rp-portfolio>python manage.py runserver
Watching for file changes with StatReloader
Performing system checks...
System check identified no issues (0 silenced).
Exception in thread django-main-thread:
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\base\base.py", line 217, in ensure_connection
self.connect()
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\base\base.py", line 195, in connect
self.connection = self.get_new_connection(conn_params)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\oracle\base.py", line 229, in get_new_connection
**conn_params,
cx_Oracle.DatabaseError: ORA-12505: TNS:listener does not currently know of SID given in connect descriptor
The above exception was the direct cause of the following exception:
File "c:\users\odoo\appdata\local\programs\python\python37-32\Lib\threading.py", line 917, in _bootstrap_inner
self.run()
File "c:\users\odoo\appdata\local\programs\python\python37-32\Lib\threading.py", line 865, in run
self._target(*self._args, **self._kwargs)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\utils\autoreload.py", line 54, in wrapper
fn(*args, **kwargs)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\management\commands\runserver.py", line 120, in inner_run
self.check_migrations()
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\management\base.py", line 453, in check_migrations
executor = MigrationExecutor(connections[DEFAULT_DB_ALIAS])
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\migrations\executor.py", line
18, in __init__
self.loader = MigrationLoader(self.connection)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\migrations\loader.py", line 49, in __init__
self.build_graph()
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\migrations\loader.py", line 212, in build_graph
self.applied_migrations = recorder.applied_migrations()
73, in applied_migrations
if self.has_table():
56, in has_table
return self.Migration._meta.db_table in self.connection.introspection.table_names(self.connection.cursor())
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\base\base.py", line 256, in cursor
return self._cursor()
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\base\base.py", line 233, in _cursor
self.ensure_connection()
self.connect()
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\utils.py", line 89, in __exit__
raise dj_exc_value.with_traceback(traceback) from exc_value
self.connect()
**conn_params,
django.db.utils.DatabaseError: ORA-12505: TNS:listener does not currently know of SID given in connect descriptor
C:\Users\ODOO\Documents\Djano\rp-portfolio\portfolio\settings.py changed, reloading.
File "manage.py", line 21, in <module>
main()
File "manage.py", line 17, in main
execute_from_command_line(sys.argv)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\management\__init__.py", line 381, in execute_from_command_line
utility.execute()
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\management\__init__.py", line 325, in execute
settings.INSTALLED_APPS
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\conf\__init__.py", line 79, in __getattr__
self._setup(name)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\conf\__init__.py", line 66, in _setup
self._wrapped = Settings(settings_module)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\conf\__init__.py", line 157, in __init__
mod = importlib.import_module(self.SETTINGS_MODULE)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\importlib\__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 724, in exec_module
File "<frozen importlib._bootstrap_external>", line 860, in get_code
File "<frozen importlib._bootstrap_external>", line 791, in source_to_code
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\portfolio\settings.py", line 100
'HOST': 'localhost',
SyntaxError: invalid syntax
self.connect()
**conn_params,
self.run()
fn(*args, **kwargs)
18, in __init__
self.build_graph()
56, in has_table
self.connect()
self.connect()
**conn_params,
You have 22 unapplied migration(s). Your project may not work properly until you apply the migrations for app(s):
admin, auth, blog, cenou, contenttypes, leads, projects, sessions.
Run 'python manage.py migrate' to apply them.
October 18, 2019 - 14:32:53
Django version 2.2.5, using settings 'portfolio.settings'
Starting development server at
http://127.0.0.1:8000/
Quit the server with CTRL-BREAK.
October 18, 2019 - 14:33:07
(venv) C:\Users\ODOO\Documents\Djano\rp-portfolio>python manage.py migrate
Operations to perform:
Apply all migrations: admin, auth, blog, cenou, contenttypes, leads, projects, sessions
Running migrations:
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\utils.py", line 82, in _execute
return self.cursor.execute(sql)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\oracle\base.py", line 510, in execute
return self.cursor.execute(query, self._param_generator(params))
cx_Oracle.DatabaseError: ORA-02000: missing ALWAYS keyword
67, in ensure_schema
editor.create_model(self.Migration)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\base\schema.py", line 307, in create_model
self.execute(sql, params or None)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\base\schema.py", line 137, in execute
cursor.execute(sql, params)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\utils.py", line 99, in execute
return super().execute(sql, params)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\utils.py", line 67, in execute
return self._execute_with_wrappers(sql, params, many=False, executor=self._execute)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\utils.py", line 76, in _execute_with_wrappers
return executor(sql, params, many, context)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\backends\utils.py", line 84, in _execute
return self.cursor.execute(sql, params)
django.db.utils.DatabaseError: ORA-02000: missing ALWAYS keyword
During handling of the above exception, another exception occurred:
main()
utility.execute()
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\management\__init__.py", line 375, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\management\base.py", line 323, in run_from_argv
self.execute(*args, **cmd_options)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\management\base.py", line 364, in execute
output = self.handle(*args, **options)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\management\base.py", line 83, in wrapped
res = handle_func(*args, **kwargs)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\management\commands\migrate.py", line 234, in handle
fake_initial=fake_initial,
91, in migrate
self.recorder.ensure_schema()
(venv) C:\Users\ODOO\Documents\Djano\rp-portfolio>python manage.py makemigrations
No changes detected
Running migrations:
main()
utility.execute()
Running migrations:
main()
utility.execute()
Running migrations:
main()
utility.execute()
October 18, 2019 - 15:02:44
Internal Server Error: /cenou/
cx_Oracle.DatabaseError: ORA-00942: table or view does not exist
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\handlers\exception.py", line 34, in inner
response = get_response(request)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\handlers\base.py", line 115, in _get_response
response = self.process_exception_by_middleware(e, request)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\core\handlers\base.py", line 113, in _get_response
response = wrapped_callback(request, *callback_args, **callback_kwargs)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\cenou\views.py", line 9, in index
patient_nb = Patient.objects.all().count()
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\models\query.py", line 392, in count
return self.query.get_count(using=self.db)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\models\sql\query.py", line 504, in get_count
number = obj.get_aggregation(using, ['__count'])['__count']
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\models\sql\query.py", line 489, in get_aggregation
result = compiler.execute_sql(SINGLE)
File "C:\Users\ODOO\Documents\Djano\rp-portfolio\venv\lib\site-packages\django\db\models\sql\compiler.py", line
1100, in execute_sql
django.db.utils.DatabaseError: ORA-00942: table or view does not exist
[18/Oct/2019 15:02:57] "GET /cenou/ HTTP/1.1" 500 124680
October 18, 2019 - 15:09:01
Running migrations:
main()
utility.execute()
Running migrations:
main()
utility.execute()
Running migrations:
main()
utility.execute()
Running migrations:
main()
utility.execute()
No changes detected
Running migrations:
main()
utility.execute()
91, in migrate
