---------------------------------- MIDDLEWARE CHECK TOOL RESULTS ----------------------------------
---------------------------------------- 11/10/05 12:39:20 ----------------------------------------
Starting to check if the middleware components are correctly installed (DB2 Connect, IBM).
DB2 Path Name...
Cannot open the Windows registry key (IBM).
The middleware is not correctly installed (DB2 Connect, IBM).
Starting to check if the middleware components are correctly installed (CAE 5, IBM).
DB2 Path Name...
The middleware is not correctly installed (CAE 5, IBM).
Starting to check if the middleware components are correctly installed (CAE 6 Run-Time Client, IBM).
DB2 Path Name...
The middleware is not correctly installed (CAE 6 Run-Time Client, IBM).
Starting to check if the middleware components are correctly installed (CAE 6 Administration Client, IBM).
DB2 Path Name...
The middleware is not correctly installed (CAE 6 Administration Client, IBM).
Starting to check if the middleware components are correctly installed (Client Access, IBM).
Driver...
Cannot open the Windows registry key (Client Access ODBC Driver (32-bit)).
The middleware is not correctly installed (Client Access, IBM).
Starting to check if the middleware components are correctly installed (ODBC driver, TERADATA).
Driver...
Cannot open the Windows registry key (Teradata).
The middleware is not correctly installed (ODBC driver, TERADATA).
Starting to check if the middleware components are correctly installed (Informix Connect v7, INFORMIX).
INFORMIXDIR...
Cannot open the Windows registry key (Informix).
The middleware is not correctly installed (Informix Connect v7, INFORMIX).
Starting to check if the middleware components are correctly installed (Informix Connect v9, INFORMIX).
INFORMIXDIR...
The middleware is not correctly installed (Informix Connect v9, INFORMIX).
Starting to check if the middleware components are correctly installed (Sybase Open Client 11, SYBASE).
SYBASE...
The environment setting does not exist (SYBASE).
The middleware is not correctly installed (Sybase Open Client 11, SYBASE).
Starting to check if the middleware components are correctly installed (Sybase Open Client 12, SYBASE).
SYBASE...
The middleware is not correctly installed (Sybase Open Client 12, SYBASE).
Starting to check if the middleware components are correctly installed (Oracle 7, ORACLE).
ORACLE_HOME... ok.
Path... ok.
ociw32.dll... ok.
The middleware checking has not detected any errors (Oracle 7, ORACLE).
Starting to check if the middleware components are correctly installed (Oracle 8, ORACLE).
LAST_HOME... ok.
ORACLE_HOME... ok.
Path... ok.
ociw32.dll... ok.
The middleware checking has not detected any errors (Oracle 8, ORACLE).
Starting to check if the middleware components are correctly installed (SQL Server ODBC, MICROSOFT).
Driver... ok.
C:\WINNT\System32\SQLSRV32.dll... ok.
The middleware checking has not detected any errors (SQL Server ODBC, MICROSOFT).
Starting to check if the middleware components are correctly installed (Redbrick ODBC Driver, REDBRICK).
Driver...
Cannot open the Windows registry key (Red Brick (32) Driver).
The middleware is not correctly installed (Redbrick ODBC Driver, REDBRICK).
