1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131
| int n=...;// nombre des sommets
int T=...;// Horizon de planification
tuple arc {
int i; int j;
setof (arc) arcs = {<i,j> | ordered i,j in 0..n : i!=j};// l'ensemble des arcs
float A[arcs] = ...;
int q[i in 1..n][t in 1..T] = 1;// la quantité de produit livré a un sommet
int I[i in 1..n][t in 1..T] = 2; // niveau de stock a un sommet
float Q = ...; // la capacité du fournisseur
int c =...;// la capacité de véhicule
int t [1..T]=...;// periode temps
tuple Position {
key int id;
int x;
int y;
tuple Demand {
key int id;
int q;
{Position} Positions = ...;
{Demand} Demands = ...;
{int} Customers = { p.id | p in Positions };
tuple triplet {
int c1;
int c2;
int d;
{triplet} Dist = { <p1.id,p2.id,(sqrt(pow(p2.x-p1.x,2)+pow(p2.y-p1.y,2)))> | p1, p2 in Positions };
execute {
writeln(Dist);
// Decision variables
dvar boolean y[0..n][0..n][1..T];/* = 1 if the arc (i,j)*/
dvar boolean x[0..n]; /* = 1 if the node j*/
dexpr float Cobj=
sum(ordered i,j in 0..n : i!=j)sum(t in 1..T) A[<i,j>]*y[i][j][t]+sum(i in 1..n)sum(t in 1..T) w[i]*x[i][t]+
sum(i in 1..n)sum(t in 1..T) h[i]*I[i][t]+
sum(t in 1..T) h[0]*I[0][t] ;
//objective function
minimize Cobj;
//constraints
subject to{
forall (t in 1..T )
I[0][t]=I[0][t-1]+r[0][t]-sum(i in 1..n)q[i][t]; //Inventory definition at the supplier
forall (t in 1..T )forall (i in 1..n )
I[i][t]=I[i][t-1]-r[i][t]+q[i][t]; //Inventory definition at the retailers
I[i][t]>=0; // Stockout constraints at the retailers
I[i][t]<=U[i]; // Born Sup
I[i][t]>=L[i]; // Born Inf
q[i][t]>=U[i]*x[i][t]-I[i][t-1]; // Order-up-to level constraints
q[i][t]<=U[i]-I[i][t-1]; // Order-up-to level constraints
q[i][t]<=U[i]x[i][t]; // Order-up-to level constraints
forall (t in 1..T )
sum(i in 1..n)q[i][t]<=Q; // Capacity constraints
forall (t in 1..T )
sum(i in 1..n)q[i][t]<=Q*x[0][t]; // Routing constraints
sum(j in 1..n : j<i)y[i][j][t]+sum(j in 1..n : j>i)y[j][i][t]=2*x[i][t]; // Routing constraints
forall (t in 1..T )forall (s in 1..n)
sum(i in 1..n)sum(j in 1..n : j<i)y[i][j][t]<=sum(i in 1..n)x[i][t]-x[s][t]; // Subtours elimination constraints
q[i][t]<=1; // Nonnegativity and integrality constraints
forall (t in 1..T )forall (i in 1..n )forall (j in 1..n )
y[i][j][t]<=1;
y[i][j][t]>=0;
x[i][t]<=1;
x[i][t]>=0;
forall (t in 1..T )forall (j in 1..n )
y[0][j][t]<=2;
y[0][j][t]>=0;
execute {
writeln ("objectif=", Cobj)
