1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111
| #define GLEW_STATIC
#include <GL\glew.h>
#include <GLFW\glfw3.h>
#include <iostream>
#include "ShaderLoader.h"
using namespace std;
int main()
//Initialisation GLFW
if (!glfwInit())
cout << "Impossible d'initiliaser GLFW !" << endl;
return -1;
//Initialisation Opengl 3.3
glfwWindowHint(GLFW_CONTEXT_VERSION_MAJOR, 3);
glfwWindowHint(GLFW_CONTEXT_VERSION_MINOR, 3);
//Disable old OpenGL Support
glfwWindowHint(GLFW_OPENGL_PROFILE, GLFW_OPENGL_CORE_PROFILE);
//Open window
GLFWwindow* window = glfwCreateWindow(800, 600, "GameEngine", NULL, NULL);
if (window == NULL)
cout << "Failed to open GLFW window !" << endl;
glfwTerminate();
return -1;
glfwMakeContextCurrent(window);
//Initialisation GLEW
glewExperimental = true;
if (glewInit() != GLEW_OK)
cout << "Failed to initialise GLEW !" << endl;
glfwTerminate();
return -1;
//Coord triangle
GLfloat g_vertex_buffer_data[] = {
-0.5f, -0.5f, 0.0f,
0.0f, 0.5f, 0.0f,
0.5f, -0.5f, 0.0f
//VAO
GLuint VertexArrayID;
glGenVertexArrays(1, &VertexArrayID);
glBindVertexArray(VertexArrayID);
//VBO
GLuint vertexBuffer;
glGenBuffers(1, &vertexBuffer);
glBindBuffer(GL_ARRAY_BUFFER, vertexBuffer);
glBufferData(GL_ARRAY_BUFFER, sizeof(g_vertex_buffer_data), g_vertex_buffer_data, GL_STATIC_DRAW);
//Shader
ShaderLoader VertexShaderLoader, FragmentShaderLoader;
GLuint VertexShader = glCreateShader(GL_VERTEX_SHADER);
const char * VertexShaderPointer;
GLuint FragmentShader = glCreateShader(GL_FRAGMENT_SHADER);
const char * FragmentShaderPointer;
//VertexShader
VertexShaderPointer = VertexShaderLoader.VertexShaderCodeLoader("SimpleVertexShader.vertexshader").c_str();
glShaderSource(VertexShader, 1, &VertexShaderPointer, NULL);
glCompileShader(VertexShader);
//FragmentShader
FragmentShaderPointer = FragmentShaderLoader.FragmentShaderCodeLoader("SimpleFragmentShader.fragmentshader").c_str();
glShaderSource(FragmentShader, 1, &FragmentShaderPointer, NULL);
glCompileShader(FragmentShader);
//ProgramShader
GLint success;
GLchar infoLog[512];
GLuint ProgramShader = glCreateProgram();
glAttachShader(ProgramShader, VertexShader);
glAttachShader(ProgramShader, FragmentShader);
glLinkProgram(ProgramShader);
glGetProgramiv(ProgramShader, GL_LINK_STATUS, &success);
if (!success) {
glGetProgramInfoLog(ProgramShader, 512, NULL, infoLog);
std::cout << "ERROR::SHADER::PROGRAM::LINKING_FAILED\n" << infoLog << std::endl;
glDeleteShader(VertexShader);
glDeleteShader(FragmentShader);
//Boucle principale
glfwSetInputMode(window, GLFW_STICKY_KEYS, GL_TRUE);
glClearColor(0.0f, 0.0f, 0.4f, 0.0f);
while (glfwGetKey(window, GLFW_KEY_ESCAPE) != GLFW_PRESS && glfwWindowShouldClose(window) == 0)
glUseProgram(ProgramShader);
glEnableVertexAttribArray(0);
glVertexAttribPointer(0, 3, GL_FLOAT, GL_FALSE, 0, (void*)0);
glDrawArrays(GL_TRIANGLES, 0, 3);
glDisableVertexAttribArray(0);
glfwPollEvents();
glfwSwapBuffers(window);
//Fermeture programme
glfwTerminate();
return 0;
